- Dec 5, 2005
Q Factor is the name for this pattern, and it comes from the world of bicycles as a somewhat esoteric reference to the horizontal distance between the pedals, which coincidentally is not much different than the overall length of this knife.
The S35VN blade is .156" thick, the hidden tang is tapered and the primary bevel has a smooth convex plane. The edge bevel, which was applied by hand, is very acute so although the knife is structurally very strong, the fine edge is meant for cutting, not abuse. Length of the blade is about 3.5", and overall, the knife is about 7 3/8". The blade is held to G10 handle slabs with bronze pins, and the G10 frame is held in place on one handle scale with hidden stainless steel pins, (they're actually made from 14g bicycles spokes). Toughened epoxy keeps it all together.
These knives were ground freehand without the use of jigs, so the swedges and grind lines are all a little different, knife to knife. Full disclosure- they are not perfect, but they are pretty good.
Q Factor was designed for the outdoorsy person who appreciates minimalist gear that's up to the task with a minimum of weight and size. The target weight for these knives is 100-150 grams, and I've built 4 of them all at slightly different weights, handle thicknesses and materials, and variations of tip location.
The sheaths are designed for neck or pocket carry via removable clip. Retention is very strong, but with an easy draw via thumb break. I would recommend a secondary safety strap for use during high impact activities such as mountain biking or sky diving. They come with the Chicago screws you need for your aftermarket clip of choice
Weights and handle thicknesses are as follows;
Green; 3.4oz, 5.1oz with sheath. 9/16" thick handleSOLD
Blue; 3.3oz, 5.15oz with sheath. 1/2" thick handle
Orange; 3.45oz, 5.2oz with sheath. 5/8" thick handleSOLD
Carbon; 3.7oz, 5.55oz with sheath. 3/4" thick handleSOLD
The price for each knife is $425 USD, plus $30 shipping, (except for the green one which was my demo model for $395) to the US, (from Canada), paid via Paypal Goods and Services. If you live in a country other than the US, the shipping cost will be adjusted accordingly.
