SOLD****Scandi Customization
redsquid2
Rockabilly Interim Pardon Viscount
Feedback: +64 / =0 / -0
This is one of those deals where you buy the factory blade from Ragweed Forge, and you make your own handle and sheath.
Blade: I started with a factory-made Blade from Karesuando Sweden, stainless. I don't know what kind of stainless, because it doesn't say on the Ragweed Web site. Length is 3 1/2". Cutting edge is 3 1/4". Thickness is .098". Width is .71". Hardness is 57 R.C.
Handle: maple wood, fiber spacer, and paper micarta. I glued up everything with the 15-minute epoxy from usaknifemaker. It is burnished and finished with several light coats of Tru Oil. It has a satin finish. That is my hand in the pictures, and I wear a men's size Small glove, to give you an idea of size. I tried to size this handle a little bigger than my hand, so it will fit a bigger hand.
Sheath: I made the sheath of heavy cow hide. I dyed it black. The sheath is cosmetically imperfect, because there are brownish areas where the dye did not soak in completely. I think that gives it character. I waterproofed it with Sno Seal.
Overall length of knife: 8"
Combined Weight of Knife and Sheath: 5 oz.
$45 ships it in the U.S., via USPS Priority with Delivery Confirmation.
sedonaderm, I went to your profile and I left you a "visitor message." Thank you for your patience. This only my second transaction here on Blade Forums, in about 15 months, so I am not a pro.
I may have done something wrong in the transfer, for my account shows no record of the transfer. So, here goes again. Sorry.
I have a blade and am trying to figure out how to get a hole in the wood block I want tp use for handle. How do you get the hole straight? my drill press isn't tall enough for the 5" block of wood
Thanks for the compliments.
As far as drilling the hole, I start with an oversize block, giving myself about 1/2" of extra material top-to-bottom, and side-to-side. I put the block of wood in a vice, grab my cordless drill, and eyeball it. I drill into a squared block, with center lines drawn along the top and side, to help me drill straight. After all the glue has fully hardened, I may have to sight down the blade, and draw new guide lines on the block. if the block isn't perfectly aligned with the blade, I can correct that by removing handle material.
