- Jul 19, 2011
Cold Steel Rajah 1, CS62K. 6" flat ground Kukri blade. Bead blasted 7075 aluminum frame/bolster, and Black G10 scales. The knife is in near mint condition. Blade, bolsters, and G10 scales are flawless. It shows no signs of use and the blade and edge grinds are spot-on. Action is smooth and it locks up with ZERO play in all directions.
There is one very tiny blemish that is shown in the last picture. It's barely detectable in person. There's also no plastic on the bolsters, but as mentioned, they're perfect.
This is a discontinued and rare knife. Would make a great gift.
Ships out via Priority Mail on the next business day.
Please see spec's, this is a BIG knife!
Sold on Ebay TYD USA PP GS, I pay fees
CS62K: Rajah I
Cold Steel®
The Kukri’s best attributes and enormous potential as a weapon and a tool have been well documented in our DVD’s. Cold Steel has made different variations of the Kukri over the years, some with longer blades, and some with shorter, but never, until now, have we had a version you could carry in your pocket as a folder.
The Rajah folders, designed by Andrew Demko, are big enough to approximate the feel and heft a fixed blade Kukri. Their broad, downward curved blades exhibit the best of a Kukri’s characteristics. First, their unique shape presents their thin, hollow ground edges at just the right angle so they naturally bite deep instead of bouncing or skidding off. And secondly their points are thick, wide and sharp enough to pierce even the toughest targets.
The handle has some of the contours of fixed blade Kukri’s with the addition of strategically placed curves and finger grooves. These features will facilitate 3 grip styles. One - very close to the cutting edge where you can really choke up on the handle for fine or delicate work. Two – by the middle for ordinary chores. And three – near the end or butt where you will have the most leverage and weight forward balance for heavy cutting or chopping and where you will receive maximum reach advantage.
The only suitable lock that can sustain the incredible impact forces generated by chopping strokes with a Rajah folder is the Tri-Ad™ lock. Designed specifically to take pressure off the smaller, more fragile interlocking surfaces of a rocker lock and transfer them to a uniquely positioned stop pin that will absorb and distribute these forces through the handle frame.
Carry the Rajah as you would any folder, using the clip to attach it to any reasonably sized pocket or clip it in your waistband. In an emergency all you have to do is grab it and open it in the conventional manner or snag its unique thumb plate on the edge of a pocket and snap it open.
Rajah I
The Rajah I is truly a custom quality knife. Its handle frame and integral bolsters are CNC machined from a 7075 Aluminum billet to secure the black G-10 handle scales. And it’s built tough enough to endure countless hours of hard, brutal work.
Rajah II
The Rajah II is a more economical version of the Rajah I. It has a Grivory injection molded handle and steel liners for added strength.
Specifications
CS62K: Rajah I
Cold Steel®
Rajah I
Rajah II
Specifications
- Blade: 6"
- Overall: 14"
- Weight: 12.9 oz.
- Thick: 5.5mm
- Steel: Japanese AUS 8A Stainless
- Made in Taiwan
