SOLD Stubby Razelcliff Mid-Tech Flipper from Jon Graham
Ritt
Feedback: +135 / =0 / -0
SOLD
Rules say mid-techs are not customs, so I believe this is in the correct place.
Knife has not been used or carried, it is as from the maker.
This is a small knife, blade is 2 1/8", OAL is only 5 1/2". Handle is wide though, and the shape is great for a solid 3-finger grip. Scales are orange-peel textured Titanium.
Blade is 154CM with a Razelcliff (what I would called a reverse-tanto) grind. Front edge and main edge are sharp, really sharp, and the point where they come together is frightening. Blade is acid-etched, and it's dark enough that the maker's etch is not so clear.
Blade flips open on caged bearings. This is a relatively short, heavy blade for a flipper, so it takes some practice to figure out how to reliably flip it open. Hard to explain, but you have to apply some pressure to the tip of the flipper off-axis to build up your push, and then switch to the direction you need to open it. Once you get a feel for it it becomes second nature, and it does flip open reliably, but you should know that it does take a little getting used to.
Lock-up is totally solid. No blade play in any direction, when the blade is opened, closed, or anywhere in between. Perfectly centered. Tail-hook clip for deep pocket carry.
It's a jewel of a knife.
Asking $350, which includes Paypal fees and USPS priority shipping.
Ill take it if youre willing to ship to Canada!
Email inc
If for some reason it doesnt sent... (ryeguycarby at gmail dot com)
