** SOLD ** The 'Meerkat' Bushcrafter - Leadwood
Feedback: +10 / =0 / -0
Hi Folks
Here is my Meerkat model... but as a Bushcrafter :-)
Introducing the "Meerkat" - a compact, lightweight every day carry or utility knife.
It can be worn as a neck knife, but it's particularly suited to be worn as an appendix or scout-carry inside the belt. The Kydex sheath holds the knife firmly and the belt clip is reversible for left-hand or right-hand use. This makes out of the way for active body movement but also fast and easy to deploy with one hand.
The blade is big enough for most everyday tasks. This 'Bushcrafter' incorporates elements useful for bushcrafting like the Spear-Point profile and the sabre grind which adds strength to the blade. The handle is long enough (fourth/little finger curls around the butt) to get good leverage on the blade but also thick enough that you can get a firm grip and be able to use it for a length of time without cramping up. The jimping also helps you get a real positive grip on this little big blade, especially in wet situations. At the front is a Corby bolt to ensure the handle scales will remain attached for your lifetime. A lanyard tube at the rear adds practicality.
Tucked into your belt or backpack, it is small and light enough that you won't even notice it's there... but has the ergonomics and is big enough for just about any outdoor task. It won't chop down trees or split logs... but will do everything else!
SPECIFICATIONS
Blade: Bohler N690 (+/- 61 HRC)
Blade thickness: 2.6mm (0.1")
Blade depth: 30mm (1.18")
Blade length: 71mm (2.8")
Overall length: 154mm (6.1")
Handle material: Oiled Leadwood with vulcanized fibre liners
Fittings: Brass Corby bolt and lanyard tube
Weight: 88g (3.1oz)
Weight with sheath: 136g (4.8oz)
SOLD
Also in my webshop with a few more pics: The 'Meerkat' Bushcrafter - Leadwood
Thanks for looking!
Paul
Your meerkat series looks to be very well done, and most attractive. If Santa Claus brought any one of them to me, you'd hear my shrieks of delight all the way off in Austria. I confess I have been naughty this year, though...the story of my life. They are still very cool knives for sure.
