- Nov 26, 2018
Hi Folks
And here is the third of three Meerkats. If you like the knife but would prefer a different handle material, drop me a message. I am hoping to do another small batch of these before Christmas.
I was trying to come up with a practical neck knife and played around with a 2-finger design. I found that a 2-finger handle just didn't give enough grip on the knife to make it really usable - not enough leverage on such a short handle. I also played with the thickness of the handle and found a thicker handle gives one a lot more purchase and control than a flat or Paracord wrap handle. My design grew bigger, as did my pile of prototypes! It took about a year going through various iterations before I arrived at the "Meerkat" as you see it.
It can be worn as a neck knife, but it's particularly suited to be worn as an appendix or scout-carry inside the belt. The Kydex sheath holds the knife firmly and the belt clip is reversible for left-hand or right-hand use. This makes it concealable, out of the way for active body movement but also fast and easy to deploy with one hand.
The blade is big enough for most everyday tasks and has a Drop-Point profile which really works well as a hunting blade. The handle is long enough (fourth/little finger curls around the butt) to get good leverage on the blade but also thick enough that you can get a firm grip and be able to use it for a length of time without cramping up. The jimping also helps you get a real positive grip on this little big blade, especially in wet situations. At the front is a Corby bolt to ensure the handle scales will remain attached for your lifetime. A lanyard tube at the rear adds practically.
Tucked into your belt or backpack, it is small and light enough that you won't even notice it's there... but has the ergonomics and is big enough for just about any outdoor task. It won't chop down trees or split logs... but will do everything else!
- Blade thickness: 3mm (0.12")
- Blade depth: 30mm (1.18")
- Blade length: 71mm (2.8")
- Overall length: 153mm (6.1")
- Handle material: Oiled Wenge with vulcanized fibre liners
- Fittings: Brass Corby bolt and lanyard tube
- Weight: 82g (2.9oz)
- Weight with sheath: 116g (4oz)
SOLD Euro
Also in my webshop with a few more pics: The Meerkat - Wenge
Thanks for looking!
Paul
SPECIFICATIONS
- Blade: Bohler N690 (+/- 61 HRC)- Blade thickness: 3mm (0.12")
SOLD Euro
Thanks for looking!
Paul
