- Oct 21, 2010
up for grabs is a lightly used v10r.
i threw away the original box so this sale is for the light only.
Features and Specifications:
CREE R5 LED, with a lifetime of up to 50,000 hours;
Digital Sensor Magnetic Control system, Infinite Variable Output Switch- slightly twist the Rotator Ring from left to right for Min to Max output.
Max: 210 Lumens (1.5hrs)
Min: 1 Lumen (35hrs)
Constant current circuit, constant output
Effective range of 130 meters
Uses one single CR123A Lithium battery
Working voltage: 0.9~4.2V
High quality reflector maintains great throw distance and spread, as well as perfect beam pattern
Dimensions: 82.8mm (length) x 23.2mm (head diameter)
Weight: 46g(battery excluded)
Aerospace-grade aluminum alloy
Military Specification Type III- hard anodized body
Waterproof, in accordance with IPX-8 standard
Ultra-clear tough glass lens resists scratches and impacts
Tactical forward click switch for momentary on
Tail stand capable- can be used as a candle
Included Accessories:
Pocket Clip
2 additional O-rings
Rubber cap
lanyard attachment with lobster claw clip
Operation:
Momentary-On: half-depress the tail cap switch and the light is momentarily turned on, release to turn off. There is no noise during this operation, no need to worry about drawing the attention of the target or prey; the mode you turned on momentarily will be the mode the rotator ring selects.
Constant-On: fully-depress the tail cap switch until a "click" sound is heard, and the light is turned on and locked; fully-depress another time and "click", the light is turned off. When the light is turned on, the mode of the light is that which the rotator ring selects.
Mode Switching: with the advanced digital sensor magnetic control system, slightly twist the rotator ring from left to right for increasing brightness of different levels. You can select your desired mode before turning on the flashlight, or you can turn on the light and then select the mode by twisting the rotator ring.
i'd like $70 shipped tyd.
paypal and conus shipping only.
the first "i'll take it" that can provide immediate paypal payment....takes it.
Pocket Clip
Rubber cap
Operation:
