Dharmaspirit71
- Mar 8, 2014
Flying Phoenix is created based on classic Han Jian design and optimized to deliver the fastest and the most powerful "Thrust" and "Strike" sword technique.
Flying Phoenix is considered by LK Chen to be his masterpiece and the foremost sword in the LK5 collection.
Flying Phoenix has a 20 cm (7.8") handle and is primarily a single handed sword with the option of using 2 hands in certain techniques.
The hilt has an oval cross section profile for accurate edge alignment.
Blade
Blade only weight: 610 g (1 lb. 6.5 oz)
Sword only weight: approx. 795 g (1 lb. 12 oz)
Blade length: 86 cm (34"),
Handle length: 20 cm (7.8"),
Total length: 106 cm (41.8"),
Slightly pronounced tapering
Width at hand guard: 32 mm, Width at tip: 15 mm
Thickness: 7.2 mm - 2.5 mm at the tip
POB: approx.13 cm (5.1") from hand guard
Blade Profile: diamond 4 surfaces
Superior heat treatment:
Hardness 54-55 HRC.
Blade rebounds to true after bending,
Cut bamboo with ease.
Hand polish to smooth soft shine and sword sharp edge.
The Celebrity Grade
Folded pattern steel:
1060 carbon steel + T9 tungsten-vanadium high-speed tool steel.
1060 carbon steel
Element %
Carbon 0.55-0.660
Manganese 0.60-0.90
Phosphorus <=0.040
Sulfur <=0.050
Element %
Carbon 0.85-0.94
Silicon <=0.35
Manganese <=0.40
Phosphorus <=0.035
Sulfur <=0.030
Tungsten <= 0.30
Vanadium <= 0.02
Chromium <=0.25
Nickel <=0.20
Copper <=0.25
Molybdenum <= 0.20
Braid leather wrap cord.
Fittings
Industrial grade precision case brass fittings. The hand guard is in the shape of spreading wing of a swift flying bird.
Fit and finish
We perfected the fit and finish of our swords and the final assembly is meticulously performed by our senior craft masters. It takes a skill craftsman one whole working day to assemble our sword to a precision fit.
Blade
Hardness 54-55 HRC.
The Celebrity Grade
1060 carbon steel
Element %
Carbon 0.55-0.660
Manganese 0.60-0.90
Phosphorus <=0.040
Sulfur <=0.050
Element %
Carbon 0.85-0.94
Silicon <=0.35
Manganese <=0.40
Phosphorus <=0.035
Sulfur <=0.030
Tungsten <= 0.30
Vanadium <= 0.02
Chromium <=0.25
Nickel <=0.20
Copper <=0.25
Molybdenum <= 0.20
Fittings
Fit and finish
