Sold
Feedback: +54 / =0 / -0
Brand new only out for pics.
(Asking 247 zelle only please) šŸ™šŸ» (Conus only )
The brainchild of Spyderco co-founder Sal Glesser, the Edgeratiā„¢ translates his deep interest in high-performance sports cars into a remarkable knife design. Its pierced, geometric handle was inspired by the frame of the legendary ā€œbirdcageā€ Maserati, which revolutionized sports car design. True to that spirit, the Edgerati’s handle scales are painstakingly machined from solid aircraft-grade aluminum and hardcoat anodized to create an exceptional blend of strength, light weight, non-slip texture, and dramatic style. They also provide a view of the knife’s streamlined Compression LockĀ® mechanism, which consists of a stainless steel lock bar nested into a machined pocket in the obverse-side scale. The knife’s straight-spined, full-flat-ground blade is crafted from CPMĀ® S30VĀ® particle metallurgy stainless steel and features a textured index-finger choil that allows a forward-positioned grip for enhanced control. Its broad-based pocket clip is reversible for left or right-side tip-up carry and complements the blade’s fully accessible Trademark Round Holeā„¢ to allow swift, positive deployment with either hand. The Edgerati is available with a satin-finished blade and brightly finished hardware and in an all-black configuration featuring a Diamond-Like Carbon (DLC) blade coating, black anodized scales, and a matching black-coated lock bar, clip, and hardware. Both finish options offer a choice of either a PlainEdgeā„¢ or fully serrated SpyderEdgeā„¢ blade.
C266ALP
TECHNICAL SPECIFICATIONS
Overall Length:8.22in 208.788mm
Closed Length:4.7in 119.38mm
Blade Thickness:.145in 3.7mm
Tip Carry Position: Tip-Up
Sheath: N/A
Blade Length:3.57in 90.678mm
Edge Length:3.07in 77.978mm
Handle Material:Aluminum
Lock Type:Compression
Origin: United States
Steel: CPMĀ® S30VĀ®
Knife Weight:3.3oz 94g
Clip Position:Ambi
Grind: Full-Flat
