- Feb 27, 2006
if you attach the guard before heat treat, it will be very difficult to finish sand the ricasso.
Good luck
Ok that right there is BAD ASS. I need on of those, clamp onto the tang and plug in.
There is a loveless video, I have the book but no video.
A little tip I can give about soldering is how to control where it goes. When I do it I put a pencil line where I don't want the solder to go. The solder will not cross the line and it acts like a dam. That being said you can use this to do all kinds of things. If you want to solder from the top then use the pencil and make the point blunt and draw around the seam where you want solder. This will put pencil line on both sides of the seam that needs soldering. I then make the pencil line wider and your good to go.
personally,
i care too much to the integrity of my hands.
I would never use a knife that does not have a guard bound to the blade with pin. In my opinion the only brazing is not enough, the real strength is made by 2-3 mm steel pin that runs through guard and blade.
These are my pics, i use stay brite silver solder and black & decker hg1300 dual temperature heat gun
this pics after a short cleaning on buffing weel
my two cent
________________________
riccardo mainolfi
All of the photos in the book are from the video.
Anyone know where to find the video?
