- Oct 19, 2011
I'm not judging who's technique is better. I'm taking notes from everybody! I'll probably use a bit of all these methods in time depending on the circumstances. I'll try a few ways and see what works for me. But even between techniques there is overlap in certain areas and that is a good place to start. I think I was on the right track initially but just didn't get the heat high enough or fast enough. I have another guard to solder coming up soon so I want to get as much information as well as tips and tricks as I can collect. You guys are the best!
Then, I have another blade (80CrV2) which will be cold blued and it will get a 416 stainless guard. should the tang area under the guard joint be masked so there is clean bright steel to which the solder can adhere or will the solder work over the bluing? Or is this a better job for epoxy?
gg,
What is the consistency of the heat sink mud? Is it stiff like wallboard spackle or more runny like toothpaste? Will the HS mud put in front of the guard stay there if turned upside down without the Dixie cup? Does it change consistency when the heat is applied? That is to say, does it get baked on and crusty or can it be easily wiped away after the soldering is complete? Can you post a picture of what your propane flame looks like when it is at the intensity you feel is best for your technique?
gg,
