- May 26, 2020
Hi all, I'm Drake and I've decided to have a go at knife making. I've had a great time reading through all of the resources that have been compiled here, so thanks for getting me off to a good start!
I have a few questions that I'd be interested to hear y'all weigh in on! I hope they aren't too redundant.
First, I built a filing jig because the only power equipment I have is an angle grinder and a drill press and I figured I'd rather make the bevels with a file than an angle grinder. One of the methods I've seen to use the jig involves starting at a relatively obtuse angle and grinding up the blade toward the spine (lowering the eyebolt) as you go in order to avoid overgrinding at the spine. I definitely plan to try this method, however it seems more controlled to me to use the chart here: (https://www.bladeforums.com/threads/knife-bevel-rule-of-thumb.659580/) to calculate the desired angle for your desired materials.
For example: Say I'm using 1/8th inch thick steel that is 1 inch wide and I want a full flat bevel. The chart suggests I should grind each bevel at 3.6 degrees to achieve this, which I should be able to establish on my jig trigonometrically (for the 12 inch hole I would need the eyebolt to be 3/4 inch tall to get ~3.6 degrees). Am I thinking about this incorrectly in some way? Also, how can I think about reproducibly making a distal taper? This doesn't seem as simple to calculate.
Second, I am pretty quantitative and not very "artistic" or design oriented. I thought about using CAD software to design my knives, but became overwhelmed and just did the old paper/cardboard trick instead. What is the general consensus around here on CAD vs cardboard? I tried some of the more highly recommended programs from the forums (Fusion 360, Sketchup, etc).
On a follow up-- do y'all have any comments on those two designs? I wanted to make kitchen knives, but have now decided that 1/8th inch is too thick for the kitchen so I'll be ordering some more steel soon. So, these will be more outdoor oriented... One is intended to be more of a EDC/defense type knife, and one is intended to be more of an all around outdoors/camp cooking/etc type of blade. I tried to keep things simple and relatively easy for a beginner, so please point out anything that you think will be trouble!
I also have designed two plunge lines for each-- in the thin one, I can envision it either going straight up to the spine or doing more of a scandi grind and bringing it out to where the clip meets the spine. I prefer the latter but am unsure of the difficulty. On the other, I'm just not sure if I should square the plunge with the blade or the handle given that they are not parallel. I think square with the handle looks much better.
Third, I have decided to go with 1084 for now as it seems pretty conclusive that it is the best for home HT. I have read about both using a propane torch as well as using a coal fire to HT 1084. I could do either, but I have a large outdoor propane burner for homebrewing (often called a turkey fryer as well). I haven't seen anyone else using this for HT, but it seems like it would work very well for temperature control as well as even heating of the whole blade. Any comments on this?
Fourth, I am curious about the temperature control necessary in tempering. From what I understand, you basically want the carbon in the martensite to be labile enough to relieve stress but not so much so that it crashes out as big cementite crystals. It seems like around 400F is ideal for this, but specific control is not important like it is when near the critical point-- so a home oven works fine? Does anyone have some specific further reading to suggest on this?
Finally, what exactly is a positive included angle? That just simply means that the edge of the knife blade is lower than the bottom of the handle steel? Whereas a non-positive included angle blade would just be in line with the handle? So one of my designs has the positive included angle, and one doesn't?
Sorry for the wall of text, and thanks so much for any help! Cheers.
