No, the sampling is too small and the changes too many to make a direct comparison. But, the increase in media cut was similar to the other differences between edge angles. The 7 degree drop from 27 to 20 increased media cut close to the same amount as the 7 degree drop from 34 to 27. The 16 degree drop from 50 to 34 also coincides with the 14 degree drop from 34 to 20. 120 grit is only about a 250-300% increase in particle size over 45 micron. 3 micron to 45 is a 1500% increase, and the average impact on results was far less than 10%, and was also in favor of the smaller particle size. I cannot be conclusive at all, but I doubt the grit played a large factor when compared to change in edge angle.I am very curious of what you found with the 120 grit, 20 degree edge tests. With the understanding that you only had a data population of 2, do you have a gut feel of how they would perform if you had a larger sample size i.e. do you suspect a large spread?
That would be great, thanks. The metallurgist had also said they would charge $200-$400 per blade if they had the time, so any better than that would be nice.There is one here that I use for work that was happy to give me a quote for some knife testing late last year. I can send an address and info if you're interested. They quoted a reasonable price for sectioning a blade for microhardness from edge to spine, checking for softening from belt sander sharpening.
