I've wanted a Buck Vantage for a long time because every time I saw it in the store, I thought the design looked very ergonomic. However, every time I picked it up and examined it, I thought it was expensive for what you were getting. I'm still looking for the full size edc holy grail and ended up buying a Spyderco Para Military 2 a while back. Unfortunately, while I think that knife is bombproof, when you are doing tough cutting into wood, for example, the compression lock on the top of the handle really digs into the thumb groove at the base of your thumb. I also think the constant curve of the blade edge is not the greatest cutting shape.
So yesterday I plunked down over a hundred bucks for a Buck Vantage Force Pro with the blue-black G-10 scales and black S30v blade. I'll comment on the Vantage line later, however, here some immediate observations. I had 5 of the same model, 847BLS-B, to choose from. Most of them had very late lock up, so they were out. All of them had rather stiff and slow deployment but I'm hoping that improves over time. None of them had any side to side blade movement when opened. However, when I got home, I noticed that when the knife is closed, you can easily move the tip of the blade to touch the steel liners. So what's happening already, is that as you flick it open with your thumb, the tip to belly section can ride along the inner edge of the steel liner resulting in scratches and a dull front of the blade. WTF? THis is a hundred dollar knife! Pretty much every time you try to flick it open quickly, the blade wipes the liner edge. I love the ergos on this knife - the shape, the contoured and grippy G-10, the blade shape - but the blade movement is definitely a deal killer. And, Buck advertizes this knife as a super strong self defense knife. Really? Lastly, I clipped the knife to my pocket and low and behold the black coating is coming off all over my pants! Geesh! So I'm curious what others have found with this knife? BTW, the knife came very sharp!
Now, about the line up. Buck has this model line so well stratified it's uncanny. For example, I usually like Sandvik better than S30v, but will say I have never had S30v from BOS, so that remains an unknown. I tried to find a model I liked with the Sandvik, but couldn't make it work. For example, I definitely wanted the back space filler strip and you can only get that on the higher end S30v models. I almost went for the Sandvik model anyway, but then discovered that is you want the stronger liner lock you have to get one of the S30v models anyway. And then, if you want the blue-black contoured G-10, you have to take the black blade. Hopefully, the black blade coating doesn't wear off on my pants like the coating on the clip is doing.
So there you go. I really don't know if this knife is going to work out. I'm not going to spend an hour sharpening the blade just to have the liner f it up. Anyone have any comments that might help?
Looking for a left-handed large Sebenza preferably with micarta or some other inlay
