It is normal for the edge to not form clean and instead be chipping under magnification? How large are the chips and what is their nature (shape).
Well, I just got the little scope, and haven't had the paramilitary for a terribly long time, so I don't have a reference for it. But, as I noted in another thread about S30V burring, this blade burrs very quickly and easily. After I received it (dull, unable to slice newsprint) I sharpened by first cutting with the D8XX, then cleaning that up with fine SiC, then the sharpmaker med & fine, and finally loaded leather. I have raised and removed a burr through all steps a few times on this blade, including burrs from the fine SM. I would hope I'm not dealing with poor steel at the edge at this point.
I am a little surprised by the chips, as they are somewhat significant under magnification, semicircular in shape. I ignored slight irregularities in the edge, those that you might imagine as appearing similar to a line drawing where you begin by using a ruler as a straightedge, and then somewhere along the way you remove it and try to continue the line as best you can. Keeping track of these would be difficult, and they could be dependent on the way the blade was profiled as much as how it was sharpened. But these chips are distinct, not something I lose with a slight shift of focus as I move along the edge viewing. I may be stressing the edge a bit on the corners of the SM rods, but I finish on the flats and then move to the leather.
Does VG-10 behave in a similar manner, chipping as the main source of blunting?
Sorry, I don't currently have a VG10 blade. But I have just gathered up 10 blades that I will do cardboard cutting with-
2 BM balisongs, one in D2, the other should be 440C or 12C27 (will check to make certain)
my M2 Rittergrip (which, under the same magnification, has what I would call a perfect edge-no chips, and as straight an edge as I can see)
G10 Cara Cara
CRKT S2 (ATS34)
CRKT Partner (AUS6, I believe)
Sorsakoski balisong style folder (Finnish, guessing 12C27),
a necker by LR Harner in CPM154
some old stainless Chicago Cutlery chef's knife I brought up to sharpen
and that little knife made from a bandsaw blade I used to hack on those sticks.
What does the first of that sentance mean exactly?
Just that I didn't get the edge as straight as I could have. I reduced almost all of the chips to where they were just slight 'wiggles' in the edge at most. A little more time on the fine stone will remove them completely, I just wanted to see what would happen to the edge with just a handful of passes on the lower grit abrasive after the cutting.
I will only really be able to simply inspect each edge for chipping, both during sharpening and cutting cardboard. I haven't established any measure of sharpness, or a corresponding way to determine blunting. I will make a matching number of cuts for each (going again with the para as well) just to see how the edges chip, but I don't have any way of measuring how well they cut in comparison beyond just how it 'feels'.
And I am really gonna want to get some pictures of this, so I will see who
I can bum a decent camera off of.
