This is just notes about my experiences in initial edging and testing of my Spyderco 52100 Mule this morning.
You gotta start some place, so I decided to start with my usual 10 degree main bevels with 15 degree micro-bevels, and test for edge durability.
I seem to recall the target hardness was around 61. Judging by re-beveling effort, mine is at least that, perhaps harder. It's hard enough to notice that my DMT Coarse (Blue) stone needs replacement, so I used 400-grit wet/dry paper for installing the main 10 degree bevels. Actually the larger working surface of the Handamerican Scary Sharp system and flexibility of grits is such that I probably will not replace the DMT.
With the main bevels installed, I used the Spyderco Medium ceramic bench stone to polish the main bevels and install the 15 degree micro-bevels. Finished off the bevels by stropping with CrO on leather. Quick testing for sharpness with newsprint. The blade takes a fine edge - whispering through the newsprint.
My usual test for edge durability is:
- Test for initial sharpness.
- Two pointings on a hardwood rake handle with hard slicing pressure.
- Examine edge for damage or reduced sharpness after the test.
With 10/15 bevels, blade steels like S30V, BG-42 and VG-10 pass this test (Tested: Spyderco Manix, BG-42 Military and Ronin).
The 52100 Mule failed, with very noticeable chipping in the most-stressed center of the edge. This was chipping only, not large tear-outs. Absolutely no edge-rolling. Re-beveling was required to remove the chip-sites.
The chipping may simply be due to the 15 degree micro-bevels being too narrow. Too much exposure of the 10 degree bevels (essentially a de-burred 20 degree included angle edge), not enough exposure of the studier final 30 degree included angle edge. I'll re-install the 15 degree final bevels and try again - but as a broader secondary bevel, rather than narrow micro-bevels. A final edge angle of 20 degrees included won't stand slicing hardwoods with any steel I'm aware of.
Some things are evident:
- The quality of the Mule is excellent - suitable for finishing with handle slabs.
- The blade I received is quite hard.
- The hardness may dictate careful attention to final edge included angle (greater included edge angle for more durable edge).
- This Mule is a lot of knife for the money spent.
Thanks to Sal for a great program!
