- Jul 30, 2004
It has come to my attention that there is a load of AEB-L being sold that has both inclusions and some real bad stress problems causing it to bow significantly during heat treat. I was also told that waterjetters are having some really bad problems with knife blanks bowing up on there tables once they are cut, causing them to break off the carbide tips to the tune of 80 to 100 dollars per tip. This is typical of coiled steel that has been improperly flattened and more so this coil was probably the center of a larger coil which is the only explanation for why even a piece as short as a knife blank would pop up and break a carbide tip on a water jet. It is an issue we had early on before we added a cold roll process to our steels that all but eliminated the issue.
I want it to be known that this IS NOT OUR AEB-L and that if it was we would do whatever it took to remedy the problem. We sell the best damn knife steel we can get for all of you and take great pride in the fact that our complaint department is ME, and I take care of such issue's as promptly as possible when they come up.
Many of you have raved about our AEB-L and about our other steels as well. I am done with sitting back and taking the humble route while watching people get screwed over by steel suppliers who won't take responsibility for there own F@#*ups. Who ever is responsible for this CRAP that is circulating around, do the right thing, suck it up and replace it!
Regards,
Aldo Bruno
The New Jersey Steel Baron
Regards,
Aldo Bruno
