- Aug 26, 2012
I've recently gathered materials to build a newer, larger cylinder propane forge for heat treatments, and have given it 3 test runs to make sure it was up to the task of heating blades longer than 20". The forge itself it about 25" from end to end, and has open ends (with some blocked to help retain heat) to allow me to pass sword-sized blades through. Test run #1 and #2 were successful, with rods of 1018 steel and W1 tool steel inserted and reaching austenization temps (1500+ F) between 12 - 23 minutes depending on rod diameter 3/8" and 1". Test run #3 was done using a 1018 (as far as I can tell) wallhanger katana blank that I keep around for dimensional reference. Here is where I noticed something that baffled me...It had been over 20 minutes with all the lights out in the shop, and nowhere on the blank did I see even a hint of dark red heat. I increase the gas feed more than I did during the previous trials, and 35 minutes later temperature is still clearly not past the triple digits!?!? Trying not to panic, I brought out the two rods again and did the same test, with the same results I got the first round; 12 - 23 minutes to crit temp.
This is the first time I've experienced this problem, though I'm reluctant to say it was the blank, but other evidence doesn't point to the forge as the problem...I'm putting all heat treatments on standby until I figure out what happened. I came here to shop talk hoping that some senior/master smiths could help me identify the culprit.
