- Dec 7, 2016
I am looking to splurge and buy a new folder. Usually my money goes to fixed blades and so my folders are mid quality like kizer and bestech. But I have decided I want one higher end knife, something of greater quality, that will basically last me a lifetime. Something simple yet effective.
I need some recommendations.
Requirements are that it is a framelock, easy to maintain, built well for potential rough use and part or full ti handle.
I am after something robust that will still cut well. Something that I can take hiking and use hard and beat on, in an emergency, if required. Something that can take a little rougher use if I decide not to take a fixed blade and need something to go the extra mile.
There's nothing quite like the security and insured feeling of carrying and having a reliable knife that you know can be pushed and not fail, if need be.
Here are my current considerations:
Large sebenza 21 tanto or inkosi -potential negatives are that it has no lockbar insert and I have read that the S35vn is a little higher than normal rockwell.
Hinderer xm18 spanto non-flipper - negative is that it seems a little bulky and cumbersome. Also that it may not be the best cutter.
Reate torrent #2 - also seems potentially bulky and cumbersome. I have no experience with RWL-34
All things considered I am leaning towards a CRK at the moment.
What are you thoughts on these or do you have other recommendations?
Thanks in advance.
Get the Inkosi. Just be sure you get a drop point model as the insingo has quite a thin tip. The Umnumzaan and sebenza have tanto versions too if that is your thing. The Inkosi is like the already rock solid sebenza took steroids and became a true heavy duty knife. I consider it way better made than a reate (which are still nice mind you).
Btw the Inkosi doesn’t need a lockbar insert because the lockbar has a large ceramic ball that doubles as a detent and the lockface of the lockbar. So it is actually the ceramic ball that makes contact with the blade tang. Even the sebenzas don’t need a lockbar insert because CRK carburizes the lockbar face which means the lockbar will probably last longer than just one measly lifetime. Check out the Umnumzaan too if you like its styling better.
The Hinderer is nice too but I don’t see much advantage it offers over the CRKs. The CRK is much slimmer and nicer to carry in the pocket while the Hinderer is needlessly much bulkier. You don’t get any real advantage in my eyes from that added bulk although some might argue the Hinderer is a “stronger” knife the crks are more than strong enough for any job you would want to do with a folder. CRK also has a program where you can pay to have the blade replaced further down the road should you ever need to.
There are many that have tried to bring CRKs to their knees through hard work and use and have found the knives to be neigh on indestructible. Also imho of the knives you listed the CRKs are by far the best built and designed to be easily serviced at home; they even encourage it and include a tool.
In short if someone was to ask what framelock for a lifetime CRK would be my recommendation any time.
