Son going to the big sand box need knife ideas?
My son will soon be going off to the big sand box. He's a medic and recently told me he was looking for a fixed blade knife for his gear.
Any military guys out there, or non, doesnt matter that have any experience or suggestions for a good fixed blade. He carrys so much gear, m9 pistol, m4, and his aid packs that I am not sure on how big a blade he would actually need or use. It also needs to be molle attachable.
thanks as always for the advice.
Dale:)
ESEE3 or ESEE4 w/molle back sheath and The-Knife-Connection aftermarket scales?
I would say plain. Fancy scales he does not need. The standard ESEE 3 is a compact workhorse, will cut anything he needs it to, and although the blade is thinner than some other ESEEs, it is tough 1095 steel, perfectly heat-treated.
Dale, have to throw my vote in for the ESEE group as well, but I would want the ESEE-5 simply because it would hold up to anything from opening fuel cans, cutting fire ports in walls, prying open ammo crates, cutting sheet metal, cords, ropes, etc. etc. This is just my own preference, always have preferred a bigger blade over a smaller one. I don't think you could go wrong with any of the ESEE line.
On a side note, please tell your son from the JUST1MOR household we send our thanks to him for his service to our country and for allowing us to have the way of life we have.
Godspeed to him and his safe return home.
Be safe.
tell him the sasquatch household thanks him for his service, and says stay safe out there!
Get him a swamp rat Ratmandu or and ESEE 3 or 4.
The Ratmandu is the best knife I have ever used. Its light, holds an edge forever and has flawless ergonomics and a lifetime warranty. It has a bigger handle that is great to use with gloves on. Azwelke, David Brown, Steelnut, or any of the other great kydex benders on this forum should have sheaths ready to ship with Molle Locks.
And if not the Ratmandu, the ESEE 3/4 is great and you can't go wrong with either.
I would stick to looking for a small lightweight knife that is utilitarian.
Well, my $0.02 worth is based on several tours (I'm over on one now) and enough time in that I can retire when this tour ends. I've made most of the normal mistakes, and found what works for me. First, big blades are rarely used, and they're way too heavy to carry around all the time. Second, Japanese style blades too specialized, as they don't have the ability to do much more than slashing cuts and punctures.
If he's going into the field a 4"-5" knife is about right. I prefer a drop point, but a clip would do also. Don't go getting one of the super hard to sharpen steels; he's going to need to put an edge on it, and he'll have minimal gear. It needs to be strong enough to be whacked with a rock or a board to cut or split something, but not a "crowbar". Don't get a "fighter" or a "skinner" pattern. Get a knife with a grip that's not too big (he'll be wearing gloves a lot). Don't worry about the sheath; you can have one custom made if needed, but everything attaches to Molle.
Currently I've got two fixed blades; a chute knife from Tim Hartman and a recurve by Matt Bailey, both of which you can find photos of on this board. If I had to take just one from my collection my current tastes would be a 4" from Centofante that's in storage right now.
Frankly, I don't use the fixed blade that often. What I do use are the folders; a whittler, a little Buck with three small blades, and a Case/Bose back pocket. My guess is that, as a medic, your son is going to need some small, sharp, blades a lot more often than any big ones.
I'd also suggest he pick up the following: several really good tweezers, a couple good nail clippers, and a couple small scissors. Those will be impossible to come by in country, and he's going to see a lot more small injuries than big ones (I hope).
Another vote for the ESEE 4. I think the size is just right to be able to carry on a vest, and it's just thick enough to stand up to hard use but still not be bulky.
As others have said, send him my thanks for his service.
From experience, something he won't mind beating or losing.
Also from experience, unless he can specify a distinct need for a fixed blade, the weight and bulk sucks.
My Leatherman was more than enough 99% of the time.
I'm gonna have to put my vote in for the ESEE 4 as well. My brother in law is going on a tour to the sandbox soon (Convoy Security). I bought him an ESEE 4. After all the abuse I put mine through and it still being able to push cut paper I just had to give him one as well.
Well, my $0.02 worth is based on several tours (I'm over on one now) and enough time in that I can retire when this tour ends. I've made most of the normal mistakes, and found what works for me. First, big blades are rarely used, and they're way too heavy to carry around all the time. Second, Japanese style blades too specialized, as they don't have the ability to do much more than slashing cuts and punctures. If he's going into the field a 4"-5" knife is about right. I prefer a drop point, but a clip would do also. Don't go getting one of the super hard to sharpen steels; he's going to need to put an edge on it, and he'll have minimal gear. It needs to be strong enough to be whacked with a rock or a board to cut or split something, but not a "crowbar". Don't get a "fighter" or a "skinner" pattern. Get a knife with a grip that's not too big (he'll be wearing gloves a lot). Don't worry about the sheath; you can have one custom made if needed, but everything attaches to Molle. Currently I've got two fixed blades; a chute knife from Tim Hartman and a recurve by Matt Bailey, both of which you can find photos of on this board. If I had to take just one from my collection my current tastes would be a 4" from Centofante that's in storage right now. Frankly, I don't use the fixed blade that often. What I do use are the folders; a whittler, a little Buck with three small blades, and a Case/Bose back pocket. My guess is that, as a medic, your son is going to need some small, sharp, blades a lot more often than any big ones. I'd also suggest he pick up the following: several really good tweezers, a couple good nail clippers, and a couple small scissors. Those will be impossible to come by in country, and he's going to see a lot more small injuries than big ones (I hope).
eisman, an additional thank you from the JUST1MOR household to you as well for your service for our country and our freedoms. Excellent two cents worth of advice you shared with us. Return home safe & enjoy your retirement.
Godspeed.
Be safe.
A Grayman SubSaharan.
+1 ESEE 3 or 4. Removable handles are good for cleaning off all the nasties a medic might get into.
I took a Randall #15 and a Buck 110 along with a few other smaller knives. Randall will get him one in about 6 weeks since he's headed over, worth looking into. Put it in a Spec Ops sheath, tape the handle so it isn't noticeable and you're good to go.
I would also highly recommend the AG Russell Woodswalker with the leather pocket sheath. Fits great into the ankle pocket, super light, and is nice for eating/fine work.
With those 3 knives I didn't need much else. Rarely used the Randall, but wanted it if I needed it.
Dale, I agree pretty much with every suggestion above. Fact is, there is a huge selection of serviceable knives fit for combat theatre. I would most likely go for something decently priced, production blade with features useful for medic.
Besides your son's multitool being key item in his setup, I'd say the Gerber LMF II is a very capable low priced combat knife with a fairly good sheath system that one can position in many ways: belt, thigh drop or vest. It also has an inbuilt sharpener for basic field maintenance.
My other production suggestions are:
- Ontario Ranger Series Afghan
- Kabar mark 1 Navy
- J-P Peltonen Sissipuukko M07
Specifically the Ontario Afghan is a fulltang knife designed for combat by bladesmith Justin Gingrich (he has an extensive special operations background). There's a Afghan "Bush" model that has a slighly thinner 3/16" blade as opposed to the standard 1/4" blade. In my opinion the Bush model would be better choice.
I could also recommend Busse BATAC, having used it successfully for a year in deployment but...
a) you wouldn't probably find one anywhere in a timely fashion as they are not currently in production by the company, Busse Combat
b) you would have to get a sheath for it as it doesn't come with one
c) price is somewhat high
Let us know what you selected.
Becker BK-2 and an aftermarket sheath. A sharpened prybar is a great all purpose tool. :D
A good multi-tool and a one hand folder would round out everything he'd need.
