Lets keep things Non-heated, we've had enough of these threads blow up into pissing matches with everyone facing the wind. Do a search for previous threads and take note of how they are locked.
Were the Bravo 1 tests locked because forum rules were broken? if so by whom?
Not a opinion but fact just like you stated yourself. The blades are hand ground and some end up thicker and some thinner. Noss probably got a thinner grind like my brothers B2 and when you bash thin steel against rock you get the results seen. My brothers B2 had a very thin grind and would roll badly with light wood work but after some reshaping has been a exceptional performer. Too much faith is put into factory sharpenings and when things like this happen its always the knife itself or the company that gets questioned.
A knifes grind can vary when done by hand and thin metal is more easily damaged is all I was saying.
What in the videos indicates fossilization of the 2x4's on which the edge rolled? Also, were not the batonning and chopping into wood consistent with expected use of the blade given the advertising and labelling of the knife as 'indestructible', 'hard-use', etc.?So we are in agreement then about thin edges. I believe the BRKT crew has the best factory convex edges outside of CS Japan or a handmaker.
Extremely sharp but like you say, just because it is ground to a razors edge does not mean it was done so to facilitate chopping up a fossilized 2x4 or stone as in this case.
The advertising and hype around this blade suggested it is a 'combat hard use' knife, the Bravo2 moreso - if not, why make it so large and thick?I am all for Noss posting the results of his demos on the combat hard use beaters but when you use more refined blades like the Bravo 2 in his format it deteriorates the edge so rapidly it is really no longer testing the cutting capability.
Noss did 'test' an ESEE-4 and it did indeed perform much better (and at a much lower cost$, though Noss makes no mention of this, if I recall correctly). As to the 'finish', how does that factor in beyond aesthetics for a safe-queen? No one questions that the Bravo1 is a pretty knife, nor any other BRKT - great F&F! But there was a general expectation regarding the performance level of this particular blade... and it fell drastically short.Take the ESEE 4 for instance, the factories edge should hold up much better... That does not mean it is necessarily better(and the finish certainly is not), but may be more what a Noss fan is looking for in a from the box user.
Oh good, the thread was restarted! The previous thread on this topic was relegated to the dumbass section of BF.
I agree that the BRKT Bravo1 convex edge is fantastic... for cutting meat, soft wood, etc... but for 'hard-use'? So fine an edge is hardly suitable and should not be labelled as such.
'More refined blades'?? Do you mean 'safe-queen'? Honestly, I am curious...
As to cutting ability, that is what is investigated on the webbing after such harsh treatment on the wood - how well does the blade retain its edge, how much maintenance is required to keep it performing well after strenuous use.
I agree, edge-geometry was a primary factor in explaining the poor performance, though there is also some question as to why the edge then chipped so drastically when subjected to concrete impacts when the rolled-edge suggested a softer (more durable) HT - I personally expected severe compaction, not chipping... But I'm neither a maker nor a metallurgist.
My guess is also that many a Noss-fan is military, looking for an honest review of a knife that caters to his/her specific needs. A pretty satin blade and polished handle is probably pretty low on their list of important factors in knife performance *shrug*
