- Dec 7, 2001
Just hope I spelt his name right
After going through the TOPS knives thread (and the "commentary" thread), I noticed Mr Clark posted something which caused various people to laugh at him. I haven't quoted the exact sentence, but the gist of it is that most average knife users won't be able to tell the difference in the steel thier knife uses. You know what, he's right.
Obioviously if you want to go to extremes and say "oh no he isn't, you're saying that a pot metal Pakistan POS is made of just as good a steel of S30V, shut up" (or words to that effect) then you're just being disingenuous, please go away now and don't waste any more of your time reading this drivel.
But comparisons of same-series steels, regardless of the exact makeup, heat treat, etc, bear the point out. Let's first try to guestimate the "average user". Ignore the Special Forces Operatives, the hardcore survivalists, the mall ninjas, and the "I keep my knife virginous for SD" people, I'd guess (correct me if you think differently and can do is reasonably cohesively) somewhere between 50-70% of "EDC"s get carried in people's pockets all day and are used 4-10 times maximum. Opening letters and parcels, trimming the occasional hangnail or loose thread, nothing that could in any way be construed as major use.
So say this "average" person cutting on "average" 8 soft, easily slicable objects per day, that makes 56 cuts a week, then again the "average" person will re-hone it at the end of that week.
There's no way in **** (my censoring, not the forums) that 50-60 cuts per week on soft, pliable objects is ever going to be enough to tell you the exact qualities of the steel you're using.
So here's the basis of this.
Me: working 5 nights a week, making 200-300 cuts per night on thin sheet plastics, paper, and corrugated cardboard (1/8" to 1/4" thick). Also using for letter/parcel opening opening (say 12-15 per week), and the usual loose threads, the occasional cake, nothing really worth including.
The knives: All reprofiled to 22 degrees for the primary edge bevel. By hand, with diamond plates (go see the pics on my website, you might be able to see that despite me doing it the old fashioned way by hand, the bevels are straight and even, a max variance of +/- 0.5 degrees, not enough to make a difference). Why 22 degrees? It works for me, YMMV, etc, etc. Measured with a vernier caliper and basic trigonometry.
Kershaw Whirlwind: 440A, decent heat treat.
Smith & Wesson "flickable" HRT folder: 440C, decent heat treat.
"Maple" cheap Chinese POS: could be anything from "pot steel" at the worst to 420HC at best. Who knows with these things?
Master Cutlery Diablo (Tom Anderson designed. Gorgeous folding dagger): 440A, poor heat treat.
Using the above knives at work and at home, the differences in the steels and heat treats with regards to ease of sharpening is nil, the difference between the knives with regards to edge retention only becomes apparent after 2 night's work (plus daytime usage, say an average of 500 cycles and cuts). (If anyone's interested, I could go into more detail but this is far too long as it is to make such a simple point)
So my ~500 cuts to notice any difference compared to "mr average"'s 8-20 cuts in the same time period means what? You'll never know. Even if Mr Average managed to hold himself to not sharpening, polishing, honing, whatever his knife for long enough to notice the difference, it'll take a two months or so before he notices anything significant.
If you've read this far, well done. Why did you bother?
Just wanted to make a simple point but took far too long getting to it really. In summation, the only way an average (urban, note, I don't live in the sticks) EDC carrier is going to notice the difference between any 400-series stainless regardless of heat treat or exact composition is if they go for a two months or more without touching the blade. can anyone here really see that happen with us knife knuts?
As an addendum, also over the same time period, the Talonite EDC (same primary edge bevel) will out-cut the lot of them by around 1.75x, the ceramic on the Boker Infinity will out-cut that by a further 2x, and the titanium alloy of the Boker Orion becomes virtually useless after ~50 cuts into soft pliable stuff.
I don't own any folders with the S*V series, but I'd hazard a guess that results would be the same in that series, and that low-alloy high-carbons also come out virtually identical within thier own series. (Only own FBs with those blade materials, and they don't get used much)
EDITED TO CORRECT TYPOS
