Now that you mention it, my steel was 3/16th inch at start of forging process and not much thinner at the spine when quench time rolled around. On this knife I hot forged to rough shape and cold forged a bit to refine the bevels and the distal taper (to lazy to fire up the forge). Instead of using belts to remove stock, (out of them right now) I used large 2nd cut files to remove remaining stock. I finished to 320 grit on the bevels and flats and then shaped the too thin edge (penny thickness at ricaso, tapering to small paper clip thickness near the point) with a mere 60 grit.
I have heat treated acceptable blades (handful in my overall experience, all 1095) successfully with Wayne Goddard's recommended goop, however, I now know that was one of mistakes. With the available commercial grade quenches, I can look forward to reducing one variable in my quench success ratio. I'm not a rich fellow, but I will take the money, time, and effort to invest in some commercial grade quench. What I'm learning from the fine folks on these forums and through direct communications with individual knife makers is I'll likely be purchasing a fast and medium quench. I'd like to learn to work with all the 10 series and 5160, W1 and W2 steels (not even close to working with Damascus yet).
I'm guessing with the appropriate set up of quenches, I'll be spending anywhere from $80 to $150 bucks for the 2 speeds. But, if you think about it this way, I spend that much every couple of months on grinding belts. And those belts aren't even going to last 1/10th as long as the quench.....which could last years....from what I'm-a-learning.
Page, I do have a 5 gal bucket filled with vermiculite, which I sometimes anneal blades in overnight. I am currently placing blades vertically, point down in the medium. Should I consider placing the vermiculite in a shallow pan, and placing the blades in, horizontally, edge down, edge up?
Thanks For Any Thoughts.
