Source for 1/16" stainless
Phil705
Basic Member
I am making some kitchen knives, and am looking for a source for some thinner stock. Prefer 154CM, AEBL, or CPM154. Or another SS that you might recommend.
Thanks
Phil705
Winthrop, WA
I got some 1/16 CPM S35VN from Aldo a while ago. Profiled 12 paring knives and a couple of little toys from it
that are in my todo pile right now.
Jantz has 440-C in 1/16", other then that I don't know of any others off the top of my head. You might give Aldo a call and see if he'll grind you down a few bars.
Aldo has some S35 in 1/16". That's the only 1/16" stainless I remember seeing.
Oops Dan beat me to it :D
I have not used S35VN before. If Dan uses it, it must be good. Any particular tricks to grind or HT?
On 1/16", I would recommend to profile, drill any holes, heat treat, THEN grind your bevels. It will sure help with warping issues.
Robert
Thanks
Phil705
Winthrop, WA
Are you sure you want 1/16? I have found 1/10 to be a good starting thickness for chefs knives. Unless you are making fillet or paring knives.
Good question. I want the finished knife to be 1/16th" at the spine, but have not played around using thicker stock as a starter. What do others do??
I use .065 CPM-S35VN for the thin fillet blades. For most other cutlery blades, I use .090-.100 and grind a distal taper. That makes the center of the spine about 1/16".
