Source for birch bark
What is your source for birch bark? I would like to try my hand at doing a handle. Thank you.
Alan
Regardless where you end up sourcing it. I suggest keep it pressed flat until you use it. If its even slightly 'green' when you get it, it curls up as it dries.
Its still usable, but a pita to work with.
Its fun to work with.
One thing I discovered, gluing up with its grain running the same direction creates an irridescent sort of sheen as the handle is smoothed & polished. Alternating the grain wont.
If you can get it green, you might have a go at weaving. Thats an oldschool method of sheathmaking and many other articles too.
The stack I bought had some curling. Some pieces more than others. Soaking in water let me press them back flat.
I find that for birchbark, soaking the pieces in warm water to soften, pat dry on a towel, and use a good glue like Tightbond-II . Glue the whole stack up and press while it drys.
Here is a tip/trick:
Punch the center of each piece with a leather hole punch. If the bark is stiff and dry, do it after softening for a while (this prevents splitting).
Take a smooth piece of brass or steel rod that easily slips through the holes, wax it with several coats of car wax, and use it as a mandrel to assemble the bark squares on.
Take a cheep woodworker's clamp and drill holes through the jaws to allow the rod to pass through. https://www.harborfreight.com/hand-tools/clamps/12-in-ratcheting-bar-clampspreader-62123.html
Soak the bark in a large bowl of warm water until just pliable.
Put some glue in a shallow bowl and dip each piece in the bowl, wipe the excess off with your fingers, slide on the rod ... repeat until all are on the rod, then put in the clamp and tighten down just snug enough to be firm. Let it sit for a few minutes and snug it down a tad more.
Let it dry and cure for a day, then remove and tap the rod out by setting the stack on a board with a hole drilled through it and hitting the upper end of the rod with a mallet. It should tap right out, but if needed, turn around and repeat from the other end.
