Source for thin L6 stock?
I was wondering if anyome out there knows of a source for thin L6 - shim or strip?
Principal Metals have L6 stock from 0.18" down to 0.03". They also have 1095 from 0.25" down to 0.001".
I was thinking of trying to forge weld some billets with 100 layers to start. So I guess I'd need stock in 0.010".
Thanks in advance!
Centaur,
From far Europe, I can't give you a source for thin L6 shim stock, but I have had recent mails with Dr. Jim Hrisoulas, bladesmith and author of several excellent books. He told me that he presently starts with 300 to 450/500 layers that are 1 1/4" square and 12-18"long.
So I guess he could give you his sources. His adress:
jhrisoulas@aol.com
I have the same problem that you have!
Hope this helps.
Claude
Claude,
I think we had a similar conversation on a different thread!
I have some of Mr. Hrisoulas' books. I had the opportunity to speak with him at a show in Los Angeles. If memory serves, he normally welds 1095 and pure nickel.
I'll try giving him an E-mail. If I can locate a good source for thin L-6, I'll let you know.
According to Don Fogg, a good alternative to L6 is 15N20, which is the Swedish version of L6.
Jeff Carlisle supplies these in thin stock. He's email is:
bevo@3rivers.net
CENTAUR, I have some saw blades that are about 24" in diameter and about 1/8" thick. they're used, so they're not clean. Do you think you might be able to use them?? I also have a couple 5-6 foot pieces of 8" wide band saw blade. It is thinner than the round blades. Let me know if want a sample, and I can send a small piece of each so you can see if its anything you can use. If it is, I can send you 3-4 of the round ones, and all of the bandsaw blade material. Take care! Michael
"Always think of your fellow knife makers as partners in the search for the perfect blade, not as people trying to compete with you and your work!"
And if anyone wants L6 in thick flat stock, Daryl Meier will be rolling it next month.
Finally, L6 in flat stock.
WOW!!!!! IT SURE WOULD BE NICE TO USE L6 TO MAKE A KNIFE AND NOT HAVE TO FLAT SAND ALL THE RUST AND PITS OUT OF IT.
Yeah, it is now possible to grind 1/4" thick, giant trail knives. No more grandpa's saw from before the world war. The first one that is.
TALLWINGEDGOAT, some of my L6 is 1/4" thick. It came from the saw blade in this picture.
<img src=http://members.aol.com/l6steel/ebay/mesaw.jpg>
PS. I'm 6 foot tall.
[This message has been edited by L6STEEL (edited 22 October 1999).]
L6STEEL -
Now, that's a saw blade! Sweet Molly Malone, that thing is huge!
Centaur
L6STEEL,
How the heck to you cut that thing? And if you do not mind me asking, where is the best spot to acquire old saw blades?
Thanks
Glenn
I've got a source for saw blades down here in Tejas that has just about anything you could want. (except clean unrusted ones) From old two man handsaws for filet and kitchen blades to 36"x1/4" rounds. I imagine shipping would be a bundle though
I love my country! I just don't trust my government!
Glen, I cut it up with a big oxy acetelene outfit. I picked this one and several others up at a lumber mill. This one was under about two tons of scrap steel and the owner of the mill couldn't believe I dug it out. I traded him 2 skinners for enough steel to make 500 of em. Try any lumber mills, or scrap metal companies. Don't be shy about calling the lumber mills, all the owners I have spoken with were very interested in what I was doing. There is one problem though, most mills I have dealt with are changing to 1/8" thick blades to get more boards from a tree, so there won't be much more 1/4 or 3/16 thick ones around.I always prefer trading a knife for them instead of buying them. That way you don't have much in them, and you get some exposure with the knife.
Tallwingedgoat, yes, I treat them myself. I'm affraid not too scientifically though. The ole heat em up till they glow and douse em in old motor oil routine. I'm gettin away from that and going to send them to a heat treater till I can afford a Paragon. It must be working though, out of 200-250 knives, I've never had one come back. I'm starting to work with stainless steels now. I am sick and tired of flat sanding all the rust and pits outa this saw blade steel before I even get started on the knife.
I can't gripe though, I have made alot of money and learned alot working with it. It sure does make a good blade too. I still have enough left for about 15-20 fancy bowies, and thats all I'm making with it from now on unless I get a specific request for a knife made from it. Take care! Michael
