240mm Single Edged Hatchet. The Silky Nata is a unique 'machete' from Japan. The single edge, mono-construction blade is made from a special alloy using traditional Japanese sword steel making methods and is designed to keep its edge longer, even with continual use. The non-slip rubber handle is designed to reduce impact on the hand by up to 60%, making the Nata ideal for heavy duty applications. The blade is perfectly weighed to swing smoothly to ensure a very efficient cut. Ideal for de-limbing and clearing brush. Comes with a hard plastic sheath and easy-release belt clip. Blade Length 240mm (9.5 Inch), Weight 880g (1 lb. 8 oz.), Blade thickness 5mm (3/16"+). Single Sided Bevel.
