You don't want to use the end grain, but need to slice it up so the part you are showing is the ends of the blocks.
When I cut up spalted logs, I cut it across the log into round slabs 6" thick. Then I slice each slab into two semi-circles on the bandsaw. That will let you see the spalting that will show on the scales/blocks. Following the straight edge of the semi-circle, I slice it into 2" to 3" wide strips, and then cut those into blocks between 2X3X6 and 1.5X2X6 .... depending on how decayed the wood is.
These are stacked in milk crates to dry for about a year, and then trimmed up to expose a clean surface. I have them stabilized, and when returned sand the exposed surfaces to get them ready for use. If scales are desired, I cut them from the blocks about a week before use and let them adjust before sanding flat and installing.
End grain spalt looks fantastic, but is very prone to cracking either in stabilizing or on the handle later on.
One piece of advise.
You will get hundreds of blocks from a 2' long log. Toss any with cracks or flaws, and let them dry for six months to a year. When dry, lay them all out on the garage floor, driveway, or on a picnic table. You may think they are all great, and will be tempted to send them all for stabilizing. Do yourself a favor and pick the best 10 or 20 out of the batch. Look for good spalting and not a sign of a crack. Send them off for the first stabilizing batch. While they are at the stabilizer, pick the next 10 or 20 best out. Put them in a box and when the others get back and are cleaned up, compare the second batch to them. If you still like the second batch, send them off. Pick 20 more and repeat. Usually long before the whole batch of blocks is used up you will decide that the rest are best used for firewood. If they are all truly good, and you don't want 100 stabilized blocks ( and the expense of stabilizing them), then sell them as unstabilized blocks in bundles of 10 for a good low price ( maybe $50 for 10 to $100 for 10, depending on how good they are). You can show a representative photo of the stabilized blocks so the buyers can get an idea of what they will turn into.
I have a batch of spalted persimmon getting ready to go to the stabilizer, and will shoot some photos of the slabs and blocks this weekend.
