Scales aside.... I choose a higher grind. If the grind is the same, I would pick the more dynamic spalting.
That esquire has a killer grind. That thing is clean brother. If that were 1/8" or thinner, that would be a slicer for sure.Here is an example of two knives I really like. The scandi karda with beautiful 3d spalting and a full grind esquire with very little noticeable spalting. Both very attractive knives in my book.
I prefer as high a grind as possible.
Josiah, when you sent me the HB it was the first I'd seen with really killer spalting. It was gorgeous, and I believe I mentioned that to you.![]()
Part of the reason why I've never been that attracted to the stainless knives is because of the different texture. Now that I've had a couple in hand, I do like the hammer blows too.
I like more spalting, but I'd still take a higher grind. Function over form as I too prefer a slicy blade.
The height of the grind has nothing to do with the spalting on the blade. Rather it is a factor the the handmade aspect of the knives. I generally try for a 3/4 height saber grind. But I grind till I get the sides to match. Thats where the height of the grind is determined.
I find Andy's comment interesting. I think that it has been generally accepted that the higher the grind, the thinner the blade, hence effects on cutting performance. With a flat ground with fixed angles or a hollow ground with fixed radius, I think generally this would be a true statement. That is with everything else being equal such as blade thickness. However, Andy's process does not have a fixed convex radius grind as I understand it. Perhaps generally speaking, a higher grind might mean a thinner blade when compared to a lower grind of the same blade thickness, but effectively it might not have any bearing on cutting performance. What a high grind does have bearing on is how much spalting is showing.
.......what?
Ya. I'm totally confused now.
So...it sounds like the height of the grind only limits the amount of spalting left showing, neither are causative of the other in the sense of how the maker does it. Andy grinds until he thinks the knife is "right"; the grind height and revealed spalting are not the goals in and of themselves.
MVM, if I understand you correctly, you're simply stating that grind height alone is not a good indicator of slicing ability.
