Spartan Blades Velos 29, CPM 20CV Bead Blast Dagger Tool with Black Kydex Sheath
Feedback: +1 / =0 / -0
Our Price: $95.00
http://www.knifeworks.com/spartanbl...gertoolwithblackkydexsheath.aspx#.VanBx7vJCtU
Velos (Vee-Los) - a fitting name for this small lapel dagger-tool, Velos, is Greek for arrow or arrowhead.
Spartan Blade's inspiration for this design was the OSS lapel daggers made famous in WWII.
This everyday carry (EDC) knife-tool can be worn around the neck or in a pocket.
The Velo’s design makes it a comfortable everyday carry fixed blade with great ergonomics.
Velos is perfectly suited for back-up and survival, as it is small enough to hide almost anywhere!
The form fitted Kydex sheath comes with a stainless steel neck chain. Made of CPM 20CV, the knife holds an edge while resisting corrosion very well with 20% chromium and 1% vanadium.
Handle has a flat-tip screwdriver and hex tool cut out that can be used when sheathed (sheath is handle).
Specifications:
Knife Name: Velos
Designer(s): Iovito
Overall Length: 4 7/16"
Blade Length: 2 1/8"
Blade Thickness: 3/16"
Blade Steel: CPM 20CV
Blade Hardness: 59-60 HRC
Blade Style: Dagger with hex tool and standard flat-tip on handle.
Coating: Plain Bead Blasted
Sheath: Kydex (Black).
Weight: 0.063 LBS (Oz) (Knife)
