dennis75, assuming it is case hardened, it won't be easily filed, however even fully hard steel will be abraded by stones. However you need a decent one, some of the really cheap hardware stones are not overly effective at removing large amounts of metal however any decent one will easily chew through the steel. But again, if the edges don't meet then you have a lot of work to grind them to shape. I would indeed suggest power equipment on such steel.
-Cliff
Probably one of the nicest bayonets ever designed for looks.
Bayonets as a class suck as knives. Not their job. They are spear tips for modern pikes : rifles. They survive thrusting, levering and extraction by being spring steel composition - and hardened to spring steel standards. RC is usually in the 40's.
If your's tests into the mid 50's it could be used as a knife - but not as a bayonet. It would be too brittle - a design flop. Even a bent bayonet is a weapon - not a broken one - and can just be straightened.
Your best option - biting the bullet - is to let it go. A sharpened bayonet is not always percieved positively as bayonets are generally known to be dull military stabbers. A sharpened one will be considered made to increase pain and suffering in legal circles, if that should ever come up. But the real thing is that it is a misapplication of design to use it as a knife.
Even if it's the prettiest one out there.
Some old Soviet bayonets were hard chromed and/or case-hardened. Maybe this is the case with your SIG too. Otherwise bayonets are always made from cheap steels and they are left quite soft.
BINGO! These blades are carbon steel plated with some metalic coating. (and it's thick too!) I refinished a blade for a friend and put a new handle on it. It takes forever to rub off. I was using a 180 grit white norton ceramic diemakers polishing hone. It took forever. These hones will remove 220 grit scratches in heat treated tool and stainless steels like it's butter. It took me like 5 or 6 hours to remove all of this coating to get to bare steel.
Once you start to expose the steel you can see the color difference. The coating is silvery white, Like aluminum.
I have no doubt this is part of the original posters sharpening problem. The other problem is the blade geometry. The blade is not an inch wide and it is about .220 thick and double edged. Each bevel is literaly only a little more than twice as wide as it is thick. It literaly has a blade profile like a cold chisel. To make sharpening practical and not take the rest of your life You probably need to sharpen at like a 40° angle. (not a great angle for cutting)
