You can only use a speed controller on a DC motor. The only way to control the speed on an AC motor is to use a VFD (variable frequency drive) but the cost of these units is usually prohibitive.
With the small and cheap speed controls for AC motors, you sacrifice all of your torque and it just won't work for a belt grinder that needs torque to turn the belt against the work piece.
There's just no way to slow the Grizzly down without some good ingenuity and engineering.
Routers and a lot of handtools are field wound universal motors. AC/DC. They lose a ton of torque. DC motors lose torque unless a proper driver is used.
DC motors can be controlled with constant torque with a proper driver.
1PH AC motors lose torque fast, and risk overheating when slowed.
3PH AC motors can be speed controlled with a VFD for constant torque.
I worry a lot of people just throw out the term VFD and motor without knowing what exactly works.
I never did understand exactly why you would want to slow down a router very much.
