Fred.Rowe
- May 2, 2004
I forge all the blades I make. I have a digital gas oven and have gotten into the habit of spheroidizing, before grinding. Saves belts!:thumbup:
On the less complex steels, I start with a pbc coating, then the clay over the pbc as a hardening process.
Once I get the pbc applied [6 or 7 hundred degrees], I normalize three times in succession, just letting the blade cool to "quick hand, touch" temperature, between cycles. I them let the blades, air cool, apply the clay and harden.
I started doing this with W2 steel, when I was making some long clip points. It stopped the warp, that I had been getting, upon quenching, the blades.
Over the last week, I forged both W2 and 52100 steels into matching blades.
I used the above techniques to process both steels.
Will the 52100 get the same benifits that the W2, appears to get, from the normalizing cycles?
Do you think this many cycles is overkill, no matter what the steel used?
Some input please, Fred
