Spiderco Sprint-Run Slip-Joint Damascus & Boker Solingen M390 Slipjoint - by designer, Raphaël Duran
Feedback: +0 / =0 / -0
Two modern slip joint folders for sale, both in nice condition:
1) Spiderco Slip-joint - Full-Flat "Bjorkman's Twist Damascus", Manialgo, Italy, Ivory G10 scales (sprint run, limited edition) - very light/limited use, factory edge.
$210 shipped via UPS (U.S. only)
Blade Steel: Damasteel DS93X
Blade Grind: FFG (full flat grind)
Blade Length: 2.44 (62 mm)
Length Open: 5.92 (150 mm)
Length Closed: 3.45 (88 mm
Blade Thickness: .114" (2.9 mm)
Hole Diameter: .5" (13 mm)
Lock Type: Slipit
Handle Material: Ivory G-10
Tip Carry: Tip-Up
Clip Position: Reversible
Weight: 2.1 oz. (60 g)
Made In: Italy
2) Boker Solingen M390 Slipjoint - by French designer, Raphaël Duran - extremely light use (almost none), factory edge.
$110 shipped via UPS (U.S. only)
Blade Steel: Böhler M390
Handle Material: Black Micarta
Blade Finish: Stonewashed
Overall Length 7.31
Blade Length 3.13
Weight: 70g
Series: Boxer, Manufaktur
Designer: Raphael Durand
Made In: Germany
(***lanyards not included)
