- Dec 27, 2003
Hello fellow thinkers,
First a few questions, does anyone know where this term originated ?
I did a search using "Spine whack" and it gave me twenty pages.......so........there must be something going on here.
Now for the discussion part, I don't think it is a valid test by any means because if I understand this correctly, the knife is upside down when done.
Who pushes a knife blade up against anything upside down from the top ?
Who strikes the blade of a folding knife upside down while doing any task or chore ?
For those "spine whack failure" believers, please help me understand what the advantage is by performing this.
Does anyone else believe in a liner lock stretching or giving in or around the pivot point ?
Now for my theory, I think the liner lock spine whack test is not valid for determining the liner locks ability to hold the blade open because of this;
When the knife is struck upside down near the pivot, I think there is a very slight amount of stretching or movement that occurs in the "pivot pin" area by the downward motion and gravity and therefore causing some sort of liner/tang distortion or mis-alignment of liner, breaking contact and friction and possibly causing a "skating" effect of liner.
This IMO could cause a very slight separation of the blade tang and the liner lock, thus allowing just for a split second the liner lock to not be in contact with blade tang and possibly allowing the angle of the tang to over ride friction and cause the liner to move over (skate) to the unlock position.
Of course all this would happen in a millisecond, the naked eye could never see the movement of the liner, but if a camera could capture the stretching of the pivot area, I think you could see a gap in the liner and tang that could cause failure. Kind of like stepping on ice flat footed for more friction contact compared to heel ot toe contact. If the liner even for a millisecond becomes distorted or out of alignment with the tang, it could skate to the unlock position.
This type of liner lock failure could not occur if the knife were in an upright position and constant pressure were kept on the blade/pivot area (as long as the knife is kept in a upright position, if for a second gravity overrides and the knife is pushed to the side, it could cause the liner to unlock, which I think has happened to some users).
IMO the more pressure applied to the pivot/blade, (while holding knife in up-right position) the more the liner lock should move over farther into the locked position, but a quick snap or hit in an upside down IMO could easily cause the liner to skate over to the unlock position.
Please don't flame me,
this is something I have had on my mind ever since I first read the words "spine whack failure".
Thanks for any ideas, opinions or thoughts.
Robbie Roberson
Robbie Roberson
