- Jun 5, 2002
I think that a spine whack is a very useful test to determine if a liner or framelock was made correctly. I do agree, you don't need to, nor should you beat the knife into submission on a hard surface, all that is needed really is a firm hit into the heel/palm of your hand. Let me say this very clearly, if you hit the spine into the heel of your hand, and the lock gives, you have a defective knife that may very well one day take a finger or 2.
What the spine whack is actually testing IMO, is whether the angles of the lock and tang faces are correct. What allows a lock to slip and ultimately fail is not a stretching or a vibration, it is the angles the lock and tang were cut at. If those angles are off, then closing pressure, which can either be accomplished by exerting increasing closing pressure on the blade, or a spine whack, will cause the lock to slip to the left and ultimately out of engagement. If a lock fails a moderate spine whack, then it will also likely fail when you simply exert closing pressure on the blade, whether it be intentional, or accidental, and after all, what is a lock for, if not to resist closing?
A firm spine whack on your hand will tell you if your lock is made correctly, and if the angles of the lock face and tang face are correct, if they aren't, the lock will fail when closing pressure is applied to the blade in whatever form, a spine whack is really just a quick, easy way to see if the lock will fail under closing pressure, and if your lock can't resist closing pressure, then it isn't doing it's job, is it.
