- Oct 28, 2006
Those are great Roger, thanks. The bottom piece is particularly lovely. Do you know what the fittings are?
In addition he offers great value on these pieces as is the norm for him.
I'm from the "old school" too in that I like a pin or some type of mechanical fastener, however the truth is that the "high tect" construction adhesives used these days are stronger that the wood/metal stud or masonry block they bond.
Not sure how to word this, but I think this is still a good reason to use pins. Even if the glue is stronger than the wood or whatever, it just means the whole scale can come off, leaving a fine coating of wood fibers stuck to the tang. Pins or other mechanical methods also help reinforce the handle material itself; not just hold it on. As an extreme example, think if you made handle scales out of balsa or styrofoam. Sure the glue may be stronger than the material, but when the material itself is so weak, it will still come right off.
I don't for a moment think that an otherwise well-made knife that doesn't employ a pin is at a meaningfully larger risk of failure.
Are fixed blades the only customs to be shown at the SoS show ??
