Spyder SALTs - large and small
Feedback: +26 / =0 / -0
Traded
TOP - SALT I - C88PYL - H1 is a PH steel meaning it is a precipitation-processed alloy, that's rolled hard without heat-treating and has .1% nitrogen which acts like carbon in the steel matrix, but does not react to chlorine making rust. Surprisingly, it holds a sharpened cutting edge comparable to the premium knife steels being used in the industry by most knife manufacturers.
BOTTOM - LadyBug 3 SALT - H-1 does something no other blade steel can, It remains 100% rust free and it actually holds a sharp cutting edge. *Spyderco’s Salt Series offers a collection of H-1 folders and fixed blades with a newly added keychain-sized Salt. The new Ladybug Salt is nearly as small as your car keys and carries just as easily. Its lightweight FRN (fiberglass reinforced nylon) handle is coated with Bi-Directional Texturing® for slip-resistant cutting. It comes in stand-out Marine Yellow and easy to spot if dropped in water or on the ground. The H-1 hollow ground blade is available in a SpyderEdge or PlainEdge configuration. The LYL is clip-less with a lanyard hole to string a keychain or lanyard through. W*hether light or heavy cutting, the Ladybug Salt is a compact firecracker with explosive cutting ability in a small package that will never rust.
Trade BOTH knives for a NIB PowerPlay Paladin #540 , NIB Spyderco PE's, NIB Benchmades PE ( blue box), NIB Emerson PE's
TRADED -- July 23, 2009
