- Apr 28, 2015
Make it Spyderco Sharp!
The Tri-Angle Sharpmaker was the first product produced by Spyderco and is ideally suited for sharpening a wide range of bladed or pointed objects. The base has inserts which hold the included sharpening stones at precise angles for perfect edges and brass guards as an additional safety feature. This high quality sharpening kit is used dry--without oil, water or lubricant--and is neatly housed within the base and it's cover.
Check it out now at MooseCreekGear Online Knife Store -- Always the lowest international shipping rates and free shipping in the USA over $80!
Features:
The Black ABS Case Holds the Entire Kit and Acts as a Stand When in Use and Hold the Stones at 30/40 Degrees
Includes Brass Safety Guides to Protect Your Hands While Sharpening
The Bottom of the Base can Hold Two Stones Side-by-side for use as a Benchstone
Two Sets of High Alumina Ceramic Stone
-A Pair of Medium-Grit Stones (For Aggressive Sharpening)
-A Pair of Fine-Grit Stones (For Finishing)
The Stones are Triangular, Flat Side is used with Plain Edges--The Corners can be used with Serrations
Each Stone has a Furrow (Groove) for use with Small Pointed Objects (Fishhooks, Darts, etc)
Includes Instruction Book and DVD
Features:
