Theoretically you can fix it yourself by bending the lockbar to put more pressure against the blade BUT the detent ball needs to be seated properly (meaning if the hole might not be deep enough to accommodate the detent ball you won't get much improvement) AND you might run into trouble if you end up sending it in afterwards, so you should think on it, sending it in might be a good first route, if they don't give you an improvement you can always try the DIY route afterwards.
I’m no fan of Spyderco flippers and am on the record for not loving the action on my Domino, Southard and Dice...but, i’ve never had one shake out in a manner that could be called dangerous.I love Spyderco, but almost every one of their flippers have soft detents. The blades shakes right out.
Which models have you seen this with?...and please post pictures. Otherwise your critique of Spyderco carries the same weight as your critique of ZT.
If you want your opinion to matter, start to back it up. At this point you’re on par with “pointless internet buzz”.
Put up or shut up.
For the OP, sorry to highjack your thread. Spyderco does a better job of anyone in terms of CQI. You can buy their knives with confidence. Don’t try to fix problems beyond blade centering on your own.
Nice job on the teardown pics marrenMine was the same. I disassembled and bent in the locking tab a bit, and that made it just fine. It's still a bit soft but it's more than acceptable.
Imgur link to my teardown and thoughts on the knife, if you want to see more.
yeah, gonna send it in.I’m no fan of Spyderco flippers and am on the record for not loving the action on my Domino, Southard and Dice...but, i’ve never had one shake out in a manner that could be called dangerous.
Put up or shut up.
This thread originated in GKD where there have been...escapades. Trace things back and you’ll understand. Lots of bad info can get spread.Relax man. He never said they were dangerous. Strawman argument, and a bit unhinged.
There are lots of online videos about adjusting lockbar tension. Unless you’re absolutely certain you know what you’re doing...and are willing to bear responsibility...there’s no great reason to circumvent the Spyderco warranty process. Good call.yeah, gonna send it in.
Mine did too. I think there might be a lot of variance with their detents in this first run.Unfortunately my blade can be easily shaken out with one movement.
That sounds like a "send in" problem. Last thing I would want is a blade to open in my pocket.Unfortunately my blade can be easily shaken out with one movement.
