- Dec 19, 2002
Spyderco FB23PBBK Aqua Salt, H-1 Steel, Black Plain Edge
Spyderco FB23SBBK Aqua Salt, H-1 Steel, Black Serrated Edge
Our 1st batch of these sold out FAST! These are now on Pre-order.
Suggested Retail: $179.95 Sale Price: $96.55 You Save: $83.40
http://www.knifeworks.com/search.aspx?find=Spyderco++Aqua+Salt
Spydercos original Aqua Salt was an amazingly versatile, do-everything fixed-blade knife that was also 100% rustproof. Its legions of die-hard fans ranged from commercial fishermen all the way to military special operations personnel and they were all devastated when it was discontinued. Based on popular demand, the Aqua Salt is now back and better than ever thanks to the addition of a non-reflective titanium carbonitride (TiCN) blade coating. Like the original, it features a broad, hollow-ground blade crafted from H-1 steelan extraordinary nitrogen-based alloy that is exceptionally tough and completely impervious to corrosion. The blades deep hollow grind, drop-point profile, and full-thickness spine provide a superior combination of low-friction cutting performance, point utility, and structural strength. The handle of the Aqua Salt is made of durable fiberglass-reinforced-nylon (FRN) and is injection molded directly onto the substantial tang for strength. The handles Bi-Directional Texturing pattern provides a slip-free grip and ensures superior control, even with wet hands. To protect the knife when not in use and allow it to be conveniently carried, the Aqua Salt includes a matching injection-molded polymer sheath with a multi-position G-Clip attachment that supports belt or waistband carry. The sheaths grommeted construction also allows it to be easily lashed or flex-tied to personal equipment. Available with a PlainEdge (FB23PBBK) or fully serrated SpyderEdge (FB23SBBK) cutting edge, the Aqua Salt is a truly exceptional cutting tool that is now optimized for tactical applications.
Specifications:
Overall Length: 9.33
Blade Length: 4.78
Edge Length: 4.38/
Blade Thickness: 3.0mm
Blade Steel: H-1
Knife Weight: 4.7oz
Total Weight: 7.0oz
Grind: Hollow
Edge: Plain or Edge: Serrated
Blade Coating: TiCN
Handle Material: FRN
Sheath: Polymer
Country of Origin: Japan
Specifications:
Blade Length: 4.78
Edge Length: 4.38/
Blade Steel: H-1
Knife Weight: 4.7oz
Total Weight: 7.0oz
Grind: Hollow
Blade Coating: TiCN
Sheath: Polymer
