- Jul 20, 2011
I was reassembling my manix 2 and the stem which holds the spring broke. Has anyone else had this problem
Not that specific problem but, like you, I've taken things apart that weren't meant to be taken apart and managed to break something in the process of putting them back together. I never considered it a "failure" of the item in question, just ham fisted clumsiness on my part.
It is only a FAILURE on the OP's part - Not a failure of the knife. Please change the title.
I was reassembling
I'd think that, in general, models with RIL and integral compression locks would tie for easiest and models with Walker and compression liner locks would tie for next easiest. Only thing that would add to "degree of difficulty" would be a staked lanyard pipe. At the other extreme, the all stainless models with pinned construction would be the hardest. Everything else would fall somewhere in between.I would like to see a post that rates from easiest to hardest all Spyderco knives on the difficulty of reassemble of each model.
The Manix 2 is not the easiest knife to reassemble.
From my limited experience :
Liner locks = easy
Lock backs = not so easy
Compression locks= easy
Ball lock= not so easy
Frame lock=easy but not as easy as a liner lock.
Be careful what you get yourself into.
The cage that holds the ball on my manix broke the other day, just out of the blue. Kinda weird, maybe a flaw.
:thumbup:
Well said.
I managed to ruined a perfectly good LE blue FRN and ZDP-189 Delica many years ago by deciding for some reason to take it apart. I deformed the little pegs on the back spacer. I looked up what I was doing wrong and was able to fix it by swapping in a spare part that I had. Regardless, the knife never felt as good as it had from the factory.
Hopefully you can get your knife repaired.
Well, I guess we scared him off.
We should start a club, I have also deformed the pegs on the back spacer trying to get an endura back together. The lock backs are the hardest to reassemble in my experience. The cbbl was hard the first time but the second time it went pretty smoothly.
