Cutting industrial copper cable with a folding knife is of course blatant abuse.
Oh I would disagree. The materials involved are significantly less hard than the blade. Maybe if you are cutting against a rock to cut through the cable or against an anvil that would be a bad idea but sounds like you are just cutting the copper, plastic and maybe aluminum "armor".
I am abusing my Manix more, judging by the amount of dulling and required frequent sharpening, by cutting up the rubberized cloth that I regularly need to cut up. All of it has grit or even mud ground into it and the stone grit is HARDER than any high tech steel and so dulls my blade(s).
I can't wash the stuff before I cut it up though. I may go back to using a box knife for that.
so . . . suprsisingly . . . even to me . . . I HAVE been ABUSING my high tech steel.
Well, when you consider that I was cutting the cladding and MILSPEC thick cable, I was cutting through almost 1/2" of tough material, over half of it metal, it certainly seemed abusive to me.Being in Afghanistan, everything was of course contaminated with that fine dirt, and sometimes small bits of rock, but that's just hard on the edge, not abuse.
if I may ask, how did you maintain the pivot in a super fine dusty environnement?
I just rinsed my Manix 2 LWs and Manix 2 XLs with very hot water every couple of days, followed by a drop of CLP. If I'd spent the entire day out working on a dump site, I'd rinse at the end of the day, if I hadn't spent much time outside, I'd usually rinse 2x a week, and spend 30 seconds sharpening on a diamond stick. BD-1 gets a nice toothy edge in just seconds, whereas S-30V needs a little more time, but holds an edge longer.
John
Hi Digital,
Sorry for your negative experience. If you send it in, we'll fix it for you.
On the design or the plastic piece, The model is one of our most popular and we've sold many thousands of knives with Caged ball bearings. We've had very few problems, and many compliments on the design and materials. .
Hope we can please you some time in the future.
sal
There was a thread just a couple days ago on spyderco forums, some guys are getting together and having titanium cages made for the manix 2...could be worth checking out?
[...] When I tried to take it apart I ended up breaking the slender plastic nose off the switch that the spring rides on. I was mad about such a crappy material being used, but honestly more mad at myself for breaking it because I liked the knife. I ended up JB Welding it bavk on and it worked for awhile but then broke again. I contacted Spyderco and was sent a replacement switch. I installed it and it worked just fine for a couple years.
I emailed Spyderco and requested a replacement switch so I could get this thing operational again and sell it and Lord almighty you would think I asked for Sal's personal ATM pin based on the response I got. I was shocked and disgusted at the treatment I received from their customer service rep. I am a long time Spyderco customer, fan and advocate but they have completely squashed me over whatbis probably a $1 piece of plastic.
I hope nobody else experiences the treatment I received from Spyderco.
