- Jun 8, 2005
I didn't really need the D`Allara Drop Point, but I had put it high on my list just because it was too great a deal to pass up. On paper, it was the best deal in Spyderco's entire line, and perhaps even the best deal in its class among any company. I'm pleased to report that this is, in fact, the case. You will not find a better deal in Spyderco. Maybe anywhere.
For the purposes of the review, I'll be occasionally comparing it to a full sized Benchmade Griptillian (D2, but it shouldn't matter) that I have here. I feel that these are DIRECT competitors for a number of reasons. Lock type, handle material, blade length and price.
The first thing I noticed about the D`Allara was its size! I had no idea this thing was going to be this massive. It is slightly bigger than my para in all ways. This isn't that big of a deal, given its blade length (size comes with that), except in one annoying way. Too much of the blade sticks out when closed--way too much. This adds probably a 1 1/2 cm across when closed and it just barely fits in my watch pocket. Other than this, it's pretty comparable in size to a griptillian in every other way (including blade dimensions).
The D`allara does have a bit of heft, but that's to be expected for a knife of this sized with full bilateral steel liners. That's right, full steel liners--as opposed the Griptillian's partial liners.
The scales are FRN, and clearly derived from the Native III's design. However, something about the D`allara removes the low quality feel inherent with most FRN knives. For one, it doesn't look very plasticky somehow (those of you who disagree, please chime in), and two, it's backed up by so much steel that it FEELS solid. Like the Native III, its texture is surprisingly grippy, and i personllay have no problems with FRN durability (although I get G10 where I can). However, while it felt great in my hand, against the griptillian (NOT the minigrip, which would clearly lose this), it loses in the ergonomics area. The Griptillian is a simpler handle shape without the bump in the middle of the d`allara. The bump isn't uncomfortable to me, but it feels a little awkward. The lack of this (but otherwise similar ergonomics) on the grip gives this the win.
The blade is VG10, one of my favorites. Like every spyderco, it came extremely sharp. However, this one conquered even my para in factory sharpness. I did the arm hair test and now I have a short bald patch.
The oversized spyderhole is a preference of mine, and like the para, this one works fantastically.
This one comes in tip up only, and I prefer tip up, but this might bother tip down fans. If it makes a difference, the blade is kept in very well, just like an axis lock.
The pocket clip is one of my favorites. I love spyderco wire clips (this is my third) for a couple of reasons. 1, they're less obvious, and 2, they have no paint to scrape off.
The ball bearing lock is beautiful and works very well here. It's a bit harder to reach than the axis lock and its smooth surface could cause problems for those who work in wet environments. That said, it has some advantages over the easier to use axis lock. The coil springs are supposedly more reliable than omega springs, and there don't appear to be as many places for dirt or water to hide.
Overall, this is a real winner, and I think would barely beat out the fullsized Griptillian for several reasons:
Slightly cheaper price
VG10 as opposed to 440C (and soon 154CM)
Slightly better scales
Full steel liners
They're very comparable, but I would take the D`allara. But it won't replace your minigrips. It's way too large.
I'll be adding more as I think of it.
Just noticed today that the edge of the tang is a little sharp and can bite when reaching into your pocket, not unlike the first generation of paras, I'm told. Not a big deal in my opinion.
