Cliff Stamp
BANNED
- Oct 5, 1998
This is a very solid heavier work knife from Spyderco, not well suited to light precision work, a very different class from the UK Pen and Calypso Jr. It has a much thicker tip profile, heavier handle and in general is more robust, the FRN grip even has full steel liners.
The partially serrated section comes with a very aggressive pointy style pattern which while it can catch on softer and loose materials tends to work very well when the materials are under tension and a lot of force is used. This tends to make sense from the point of view of an emergency situation.
Initial sharpness is very high, cutting ability similar, solid ergonomics and grip security. Carries well, and the opening is easy and smooth. The ball lock is stable and strong, extended use is needed to check long term security.
Ref :
http://www.physics.mun.ca/~sstamp/knives/d_allara.html
-Cliff
Ref :
-Cliff
