- Dec 19, 2002
Spyderco Dog Tag Folder Black/Plain Edge C188ALTIBBK CPM S30V Titanium/Aluminum Handles
Suggested Retail: $129.95 Our Price: $75.95 You Save: $54.00
http://www.knifeworks.com/spydercod...s30vtitaniumaluminumhandles.aspx#.VKVrfht0zIU
Based on one of Serge Panchenkos most popular custom designs, the Dog Tag Folder is a unique departure from Spydercos typical folding knife construction methods. Its single-sided handle is fabricated from solid titanium and accurately replicates the size and shape of a military dog tag. The center of the handle scale is machined to create an integral spring bar that houses a steel ball bearing for the blades detent mechanism. At the top of the handle is a aluminum back strap that defines the blades limits of travel in both the open and closed positions and provides protection from the edge when the knife is closed. The business end of the Dog Tag is a sheepfoot-style blade made from premium CPM® S30V® particle metallurgy stainless steel with a stonewashed finish. To protect theedge when closed, the blade is chisel ground with a single flat bevel on the front sidean unusual feature for a Spyderco knife. SpydercoTrademark Round Hole in the blade allows easy opening, and a subtle swedge (unsharpened bevel) and a decorative fuller (groove) near the spine add a touch of style. The blades pivot is also accentuated by a round aluminum disk that provides stability and structural strength as well as an aesthetic touch. A non-locking folder, the Dog Tags blade is held in place in the open position by a detent mechanism. A ball bearing in the handle scales integral spring arm indexes holes in the tang of the blade to hold it both closed and open. Since the blade does not lock, care should be taken during use to apply cutting pressure only in a direction that maintains the knifes open position. This version of the Dog Tag features a black anodized handle scale and black anodizing on the back strap and pivot pin disk.
Specifications:
Length Overall: 3.23" (82 mm)
Blade Length: 1.23" (31 mm)
Blade Steel: CPM S30V
Length Closed: 2" (51 mm)
Cutting Edge: 1.14" (29 mm)
Weight: 0.9 oz (26 g)
Blade Thickness: 0.118" (3 mm)
Handle Material: Titanium/Aluminum
Specifications:
