- Dec 19, 2002
Spyderco Dragonfly2 Folder, SPRINT RUN, Super Blue, Gray FRN Handle, PRE-ORDER
We started shipping these last week!
Now on pre-order shipping the same day we get these in!
1st come 1st served !
Suggested Retail: $104.95 Our Price: $61.95 You Save: $43.00
http://www.knifeworks.com/spydercodragonfly2foldersprintrunsuperbluegrayfrnhandlepre-order.aspx
C.Q.I. - Constant Quality Improvement is a process Spyderco uses to evaluate and refine longstanding established knife models. Sometime C.Q.I. changes are large and noticeable, sometimes they're smaller refinements. Recently we applied C.Q.I. to the classic Dragonfly creating a new Dragonfly 2. The Dragonfly 2 upgrades some notable features over the classic while keeping the important basics.
Features carrying-over to the new version are the tried and tested mid-sized blade and ergonomic handle along with a front-finger choil and spine cusp. Also staying int he blade-to-handle geometry and leveraging points which make the Dragonfly cut and feel like a much larger knife when in the hand.
The position of the enlarged Spyderco Round Opening Hole in relation to the pivot leads to smooth opening and the FRN (fiberglass reinforce nylon) handle fits the hand ergonomically with a series of grip angles and leveraging spots.
Spyderco's Sprint Run Dragonfly 2 is made with Aogami Super Blue steel. Aogami Super Blue is produced exclusively by Hitachi Metals at their plant in the Shimane Prefecture, Japan. They use high quality iron-sand found only in this region to create different grades of steels including white steels and blue steels. The steel itself isn't blue or white in color but the designation refers instead to the color paper the raw steel comes wrapped in when delivered to Hitachi. In Japan its common practice for steels to be named and referred to; based on the color of the packaging the raw steel is delivered in. Super Blue is the highest grade blue steel and contains up to 1.5% carbon for wear resistance and chrome to elevate hardness and improve edge holding and corrosion resistance.
The gray fiberglass reinforced nylon handle features Spyderco's patented Bi-Directional Texturing for slip-free tactile traction. The knife locks up solidly with a mid-positioned back-lock and comes with the awesome wire pocket clip which is reversible for left or right hand tip up carry.
Sprint Runs
A Spyderco Sprint Run is defined as a limited edition production of any Spyderco product in a configuration different than what has been previously produced. It can include changes in the handle color, materials, blade steel, coatings, etc. 1200 piece Sprint Run.
Specifications:
Overall Length: 5.56"
Blade Length: 2.25"
Cutting Edge: 1.875"
Blade Thickness: .0938"
Blade Material: Super Blue
Blade Style: Leaf-Shaped
Blade Grind: Flat
Blade Finish: Satin
Edge Type: Plain
Handle Length: 3.31"
Handle Thickness: 0.335"
Handle Material: FRN
Handle Color: Gray
Weight: 1.2 oz.
Pocket Clip: Right/Left Hand, Tip-Up
Knife Type: Manual
Opener: Thumb Hole
Lock Type: Lock Back
Brand: Spyderco
Model: C28FPGYE2
Country of Origin: USA
Best Use: Everyday Carry
Sprint Runs
Specifications:
Blade Length: 2.25"
Blade Grind: Flat
Blade Finish: Satin
Edge Type: Plain
Handle Color: Gray
Weight: 1.2 oz.
Knife Type: Manual
Opener: Thumb Hole
Brand: Spyderco
Model: C28FPGYE2
