- Dec 19, 2002
Spyderco FB34GP Reverse, CTS BD1 Steel, G-10 Handle
Suggested Retail: $149.95 Sale Price: $79.16 You Save: $70.79
Estimated Shipping: March 3rd
http://www.knifeworks.com/spydercofb34gpreversectsbd1steelg-10handle.aspx#.VPR5JBvwvIU
The Spyderco Reverse is a truly unique fixed blade knife design from the minds of renowned edged-weapon trainers Craig Douglas (aka Southnarc) and Michael Janich. Although their approaches to defensive knife tactics differ significantly, they designed the Reverse to be adaptable to both systems by virtue of its distinctive reversible handle. The Reverses ergonomic handle consists of two precision-machined textured G-10 scales that attach to the tang of the blade with stainless steel bolts. When the handle is attached so the blades cutting edge is oriented back toward the user, the knife is optimized for Douglas preferred system of reverse-edge tactics. By removing the handle and rotating it 180 degrees, it can be attached to the blade to support Janichs edge-out approach to knife skills. This versatile design allows martial artists to train and experiment with both systems of tactics with the same exact knife. The exceptionally keen blade of the Reverse is full-flat ground from corrosion-resistant CTS BD1 stainless steel and features a slightly concave hawkbill profile for aggressive cutting performance. A specially designed custom-molded Boltaron® sheath holds the Reverse securely in either configuration and includes a versatile G-Clip attachment that supports fully adjustable belt and inside-the-waistband carry. Literally the best of both worlds, the Reverse sets a new standard in fixed-blade personal-defense tools.
Specifications:
Overall Length:7.74/197mm
Blade Length:3.47/88mm
Edge Length:3.10/79mm
Blade Thickness:.135/3.4mm
Blade Steel:CTS BD1
Knife Weight:3.6oz/102g
Total Weight:5.5oz/156g
Grind:Full-flat
Edge
lain
Handle:G-10
Sheath:Boltaron
Country of Origin: Taiwan
Specifications:
Blade Steel:CTS BD1
Grind:Full-flat
Edge
Handle:G-10
Sheath:Boltaron
