I will suggest that the reason you are not finding much on heat treat/hardness of H1 has everything to do with the claims that H1 is not heat treated to achieve hardness. It is work hardened.
H1 is a precipitation-hardened steel
frank thanks for the link on your testing.
I picked up the H1 version alittle while ago and think it will be an excellent knife. I plan on carrying all summer long as it should carry nice in shorts and while I am always down at the beach or lake on walks, swims, etc. I wont have to worry about rust and because of the yellow, I shouldnt have to worry about losing it!
Cant wait for the weather to get here so the shorts can come out!!
has anyone ever done a rockwell test on H1?
I'm sure Spyderco has, but they don't tell that I've been able to find.
H-1 steel is kind of a toss up. In a plain edge it wont hold that great of an edge compared to VG-10, but because of it's work hardening properties it will hold an edge the more you use and sharpen it and in a serrated model, because of all of the extra working required will give it a wicked hard (64hrc I've heard) cutting edge. So pretty much it's similar to AUS8 in a plain edge and could be up there with ZDP in a spyderedge.
Well you should be work hardening it through use and resharpening!The consensuses is that the serrated H1 blades do hold up very well.
There's no doubt about it, the extra work hardening of the PH metal makes a big difference.
I wonder if they could do more to work harden the plain edged blades.
Big Mike
