- Sep 29, 2008
The Spyderco/CLB Lava is currently discontinued in the '09 run.
The fit and finish of the knife is good. It's stainless steel construction, so nothing can be adjusted by the end user. There was some minimal side to side blade play. When closed the knife looks like a little polished gem. All the lines are smoothly curved, nothing breaking the outline.
When open, the Lava reminds me of the hunchback of Notre Dame. The blade comes to rest at a sharp downward angle. This helps align your wrist for stress free cutting.
The lock is a lockback, and is easiest to disengage if you hold the knife by the second choil.
The handles as said are stainless steel. This makes them a bit slippery, however when held, the knife really grabs your hand. It's not going to slid out. The handles give the knife a bit of heft, which is nice.
That blade shape is a drop point/leaf shaped blade, full flat grind, in VG-10. The blade has little "point" to it, and it's easiest to cut using the belly. It makes it harder to do precision cutting.
